Need urgent help, new golf won't start.
  • Need urgent help, new golf won't start.
    Ok let's try this again in the right section.
    Ok so I have borrowed a 2003 1.8 manual golf from work which might buy.
    It has just had fluids done/ filters/ new brakes/ new clutch the only thing needed is the service warning to be wiped.
    Drove home very well. Tried to start it again and nothing.
    I turn the key I get a beeeeep from the dash with every dash light on.
    Then all dissapeer except Service warning and engine light.
    Car dosnt even try to turn over then I cantturnthe key again.
    Batteries not flat. No aftermarket alarm.
    Any help needed,
    Urgent and appreciated.
    Btw hello everyone
    ---------- Post added at 08:57 PM ---------- Previous post was at 08:28 PM ----------
    Ok so I have realised that it is also givin me this.
    It beeps and gives me the service/ engine light.
    THEN I get the HOT engine red warning flash at me and 3 beeps which correspond, is it stopping me from starting? The car is cold btw and never overheated
    Maybe they didnt fit the power or earth strap on properly after they did the clutch?
    Euro Revolution - eurorevolution@live.com.au
    Importing Quality Performance and Spare parts for Audi & Watercooled VW's
    New website almost up and running ... http://eurorevolution.webs.com/index.htm
    Courtney
      Hmmm I'm getting electrics, everything works but the engine.
      Ok so sein as the hot light was flashing and beeping at me I checked the (new) coolant. I noticed leading Down Into the coolant overflow tank is 2 prongs hooked up to a sensor which did not quite reach the coolant so I topped it up. Only took about 2 cups.
      The coolant light/ beeping / warning is now gone!
      No more luck with starting, however the EPC light is on.
      Any one know their way around engine management ****? Do I disconnect the battery or reset it or something?
        you can try discinnecting the battery for an hour or so but if its a serious fault it will come right back. Best to get it scanned with vagcom/vchecker
        1991 BMW 318is RED E30
          i have it disconnected atm, gonna hook it up in the morning, if i can start it i can get back to work.
          I work at a new car dealership, the golf is a wholesale car to me, well, might not be if its a major problem.
          but i just need to get it and me to work tomorow am.
          any ideas what it would most likely be and why it was so sudden on such a smooth running car?
          i just need it to start once
            Yep seen this or something similar, check the aux fuse box on top of the battery, the heavy red can be melted in there, best way to check is to jump the output side of that with 12v from the positive terminal next to it. I had one that looked whole but had open circuit, only just so it would allow you to turn the ign on but when you asked it to start it lost everything and caused havoc with the dash. So to recap it in the aux fusebox, from memory the one i had was the one covered by the 110 amp strip fuse
            good luck
            Jmac
            Alba European
              Good advice thanks for the input, very possible actually the workshop brold the plastic clip holding the box ontop of the battery so it just sits loose. I thought nothing of it but maby it's more.
              Car didn't start thismorning :/ batt was unhooked all night
                Stupid suggestion: have you got the correct gear engaged (Park for auto), feet on (clutch) + brake
                Audi A3
                  Manual
                  But yeah tried all of that
                    Is it even cranking ?
                    Do you have a 2nd key ? Maybe the immobiliser is locking you out.
                    MK4 GTI - Sold
                    MK5 Jetta Turbo - Sold
                      no the car isnt cranking at all, just giving me a dash warning beep, and these lights EPC Engine Service
                      i have studies the book, the IMOBILIZER light is NOT on and apparently isnt halding it back.
                      i assume the EPC light i have read is the engine management light is what i assume is stopping it.
                        Ok firstly forget the immobilser altogether, even if it were locked out it would still crank and start momentarily then cut straight out so forget that. it would even start if the cluster was removed and that has the immob in it, but would cut out, so the key is crank and start. Is the fuse box on top of the batt good?? even when they can appear good they can be making and breaking inside, check the output of the fuse links are in fact 12v.
                        If it isnt cranking it cant be EPC either mate, its losing a start feed or a main feed hence check the output side of the fuse links
                        Jmac
                        Alba European
                          With no electrical testing equipment, is their something I can test or visually check, appart from obviouse unconnected things :p
                            Not much really, however these days you can get the digital voltmeter for less than $20 and that would help you a bit.
                            Also it's a handy tool to have.
                            Performance Tunes from $850
                            Wrecking RS OCTAVIA 2 Link
                              how old is the car??
                              in my Cordoba the ign lock is worn and wont start if the Key aint in a special angle and pressure due to wear!!
                              german - english translations esp vw documents!!
                              Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
