Hi all,
My MKIV (1.6 man) has developed a power steering fluid leak...
It appears to be leaking from the Banjo Bolt on the steering box where the pressure hose from the pump connects.
There appears to be a couple of washers under each side of the Banjo bolt head and I am guessing that is where it is leaking from. The previous owner replaced the pressure hose for the roadworthy (about 13000km ago) but I think they may have reused the washers.
Are there any tips or suggestions before I tackle replacing the washers to fix the leak....I'll pick the washers up this week.
Has anyone else done this job and found all the little traps
