Timing Belt Change Interval for 2.0 Mk4
  • Timing Belt Change Interval for 2.0 Mk4
    Aplologies if this question has beeb covered off elsewhere on this forum (I did a search).
    Last time I checked the timing belt on a 2.0 Golf 4 needs to be changed every 60,000Kms or 4 years. I understand that the service advice now is 7 years or 100,000Kms... however, I can't remember the source for this information. Can anyone knowlegable on this topic confim the recommended intervals?
    Many thanks
    *** It's Only a Car ***
    That will also depend what belt is fitted in your engine now. Is it the OEM belt or aftermarket? Also, is the engine modified or not? It's not so simple to answer. I would suggest 100,000km or 5 years, wichever comes first.
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
      It is an aftermarket belt and the car has no mods. When the belt was changed last I also did the tensioner and the water pump (metal impeller). Thanks for the advice.
