Fitting control arm bushes..
  • Fitting control arm bushes..
    Hi all,
    Going to try and fit some control arm bushes on the front and just wondering if anyone else has done it before? Any help would be good
    '01 Mk4 Golf GL, Engine swapped to 1.8L GTi motor, Whiteline Swaybars, Nolathane & Pedders Bushes, K&N Oversize Pod Filter, 2 1/2 inch Cat back exhaust
    They can be hit out but you will need a plastic hammer to hit back in also if you going to do the small front ones these will have to be pressed in as there way to tight
      Well it's the front inner control arm bushes if that helps
        It looks like you have the easy option with those 2 part bushes.
        They are usually 1 part with the metal sleeve pushed through.
        The single part bush needs to be pushed through, that lip makes it hard work. The 2 part looks like you put 1/2 in each side.
        The is the single style
        MK4 GTI - Sold
        MK5 Jetta Turbo - Sold
          great thread here from club tdi forum -
          HOW TO change the lower control arm bushing - TDIClub Forums
          My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
            I did a little how too ....... its near the top of the mk4 forum.
