Rear Disc Brake Tool
  • Rear Disc Brake Tool
    Hey guys,
    Does anyone know of a good/cheap Rear Piston Windback tool to fit the MKIV GTI?
    Or does anyone know if those 6 side cube things will? Similar to this Stanley Rear Disc Brake Piston Tool - Supercheap Auto Australia
    Cam.
    2001 MkIV GTI
    Revo Stg 1 - K&N Intake - Forge DV
    Hey Cam, best of just buying a kit like I did.
    Disc Brake Caliper Tool Kit | eBay
    HAHAHA
      That stanley tool wont work as the pins on it are too close together. Just use a pair of decent needle nose pliers and some elbow grease.
        **** thats cheap ryan! Bought!
        2001 MkIV GTI
          Yes the cube thing works, you have to use the side with 4 pins, but cut 2 pins off, 2 secs on a grinder.
          You also need something to apply pressure.
          If you need it today get the cube, otherwise get a proper kit. The cube thing with a clamp can be a PITA.
          MK4 GTI - Sold
          MK5 Jetta Turbo - Sold
            How to change your brake pads. ( BMW ) - YouTube
              a pair of screw drivers and a pair of nuts worked on my last car. unless theres something wierd with golfs. im yet to do a brake change
              '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
                Rear calipers on Golfs are special, they require a tool that compresses the piston back into the bore whilst also being rotated.
                When the kit arrives, from memory, adaptor D is the one to use on the rears
                HAHAHA
                  Cheers mate!
                  2001 MkIV GTI
