the typical aftermarket clutch kit that a lot seem to get is the 14lbs single mass flywheel with VR6 clutch.
I have that one (from ECS), but I hate the gear chatter you get at idle when the air con is on.
Apparantly the heavier 20.5lbs single mass flywheel stops this happening, as it is the same weight as the stock dual mass flywheel.
