Heh, Not sure what that could be but does sound like the contacts compared to mine. My door wouldn't reconigse it was open or closed so the beeper for the lights didn't work and the door light didn't work either. Turns out the micro switch that tells weather its open or closed had lost its plunger. So i ordered some new micro switches that i got from rs components but vwvortex told me which ones. They weren't the right size but i could steal the plunger and other parts to make it work again.
There is only one rivet which holds the plastic bracket on which temporarily holds the module onto the door card. Mine has broken but its not that big of a deal as the main bolts on the end hold it. You will need to drill out the rivet and either replace it or as i said use a 5mm bolt and nut. Probably easier to use a rivet if you have one. Theres only one as well.
You can see the rivet on the right side in this picture taligentx.com: Passat - Dlm 15 screws
Also this is a decent guide that you may want to look at.
taligentx.com: Passat - Door Lock Mechanism Repair
EDIT: Be VERY careful when taking the lock cylinder out. Unscrew it the very minimum otherwise it will fall out and forever be a pain in the ass.
