Bora Engine Series, How to tell the difference.
  • Bora Engine Series, How to tell the difference.
    Hi all.
    I have recently bought a Bora in need of an engine change.
    I am told there is two series of engines in Boras built around 2001.
    Does any one here know the difference, and how to tell if an engine is the early or late series?
    Are they interchangeable?
    It is also an auto, and I am told they are different from the eingines used in manual cars. Does any one know the difference here, other than flex plates / fly wheels.
    4-cylinder or V5 (can't be V6 as they were manual-only)?
    Nothing to see here...
      Engine code is under the floor in the boot next to the spare tyre on the sticker or in the car manual service section.
      - Ben
      2008 Jetta 2.0L FSI
        From memory there was a 125kw and 140kw or something similar in the V5 depending on year (not sure about the exact kw).
        2014 MK7 R
        2014 Audi SQ5
        2022 Tiggy R
        2022 Tiggy 162 Allspace
          It is a V5.
            I will take a look in the morning. There is no battery in it at the moment, so I cant get in there. (It is the hi tech security system).
            Is there a way to translate the code, and what is the physical diff?
              Be much easier if you need another engine to get the same engine code. Google the 3 letter code and there'll be something on wikipedia.
              V5 engine - Wikipedia, the free encyclopedia
                You should be able to get in the boot, Just stick the key in the lock and turn it and it should open i think? Or fold down the rear seats. Both probably not true haha.
                2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
                  110kw and 125kw
                    The 110kW engine was single cam, 10v (2 per cylinder). The 125kw version has twin cams and 20v (4 per cylinder).
                    I suspect the 110kW version also does not have individual coil packs in the head, but rather coilpacks on the side of the block like the Mk3 VR6.
                    Regarding interchangability, you could potentially put the newer engine in an older car, but not vice versa. Lots of work required I suspect due to different electronics, would also require engineering. You'd be better selling an earlier car and buying a later one with the updated engine.
                      All V5s are twin cam . Only difference you can see was early had coilpack and leads while later had individual coilpacks .
                      All 2.0l 4 cylinders are the same .
                      110kw v5 also had extractors while the 125kw had cast iron manifolds .
                      Main difference regards to the power was the extra 2V per cylinder and also much larger ports both intake and exhaust on the later 24V V5
                      Euro Revolution - eurorevolution@live.com.au
                      Importing Quality Performance and Spare parts for Audi & Watercooled VW's
                      New website almost up and running ... http://eurorevolution.webs.com/index.htm
                      Courtney
                        Thanks for that Manaz! I more wanted the info so I know what I am looking at while shopping for engines.
                        Given I have the coil packs and twin cam and the AQN code, I will assume it is the late style.
                        I have been getting prices for a new engine, and I was told (from the VIN) it has a new style and an old style by different 'experts". Neither could tell me the difference!
                        Ross
                          Yep the AQN is the 125kw V5, same as mine. Also you should see the V5 badges have a red 5, the 110kw car had all silver badges.
                          Adam
                          2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
                          Previously -
                          2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
                          2002 Bora V5
                            Ross
                            There is a guy on ebay who has a few brand new Bora V5 Engines for sale.
                            VOLKSWAGEN Bora V5 Engine complete NOS (eBay item 220675559925 end time 25-Feb-11 13:31:15 AEDST) : Cars, Bikes, Boats
                            V5 BORA ENGINE NOS (eBay item 220675584878 end time 25-Feb-11 15:07:50 AEDST) : Cars, Bikes, Boats
                            2014 MK7 R
                            2014 Audi SQ5
                            2022 Tiggy R
                              [QUOTE=sirmoe;614737]There is a guy on ebay who has a few brand new Bora V5 Engines for sale.
                              I saw.....
                              Freight is a killer,
