Changing front fog light bulb on 2001 Bora - how?
  • Changing front fog light bulb on 2001 Bora - how?
    hey guys,
    I've searched here and google for instructions on how to change the bulbs on the integrated front foglights on my Bora, but can't find anything. I bought some bulbs from Powerbulbs and changed the headlight bulbs easily but I've no idea how to do the fogs.
    Can anyone help?
    Thanks!
    its very similar to the headlights. metal wire holding the globe in.
    Ill try and find a picture of the rear after work to give you a better idea of what your doing.
    EDIT: not mine but you get the idea:
    so you want the one with the blue wire, you can see the two metal wires holding the globe down. depending on the year of your bora will make a difference to if they go 'in' or 'out'
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
      ah great, thanks mate. So i guess i just take off the black cover and it should be ok. the blue wire on the h3 bulb, where does that get plugged into? I guess I'll see it once I take the cover off.
        theres a little spade connection from memery. its all pretty simple though.
        Back covers on the fogs seem to break easy, be gentle.. Otherwise you end up with a truck load of tape like me
        Bora gone
        Vento VR6
        MKIV GSW TDI
        7P Touareg TDI
          that's what i'm worried about! are there any tabs/catches to depress? it looks like there's one on the top.
            Which bulbs did you choose for the foglights? I have changed my main globes to Philips Xtreme's but still have stock foggies.
            Adam
            2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
            Previously -
            2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
            2002 Bora V5
              yep, just at the top. Press on that, top slides off (piviting from the bottom) then one that is clear of the top tab you can lift vertically and it will slide out of a cutout down the bottom.
              X2 on what foggies you went, im thinkin ill go some super yellow ones soon
              Bora gone
              Vento VR6
              MKIV GSW TDI
              7P Touareg TDI
                I got the Philips Xtreme Power for headlights - significantly more light than stock! I need to wetsand and polish my headlights since they are a bit cloudy. For the foggies I just went with the Philips Blue Vision - they're just more for looks than anything.
                One other thing - with the small parkers, do they twist out, or just pull out? I wasn't too sure and I didn't want to force anything.
                  from memery straight out... But dont quote me on that!
                  Bora gone
                  Vento VR6
                  MKIV GSW TDI
                  7P Touareg TDI
                    oops should have been more specific. I'm sure they go pull straight out of their housing/socket, but does the housing twist or pull out? lol
                    i'll try wiggling it around haha
                      yeah think its the same deal?
                      Bora gone
                      Vento VR6
                      MKIV GSW TDI
                      7P Touareg TDI
                        yep. Parker housing is straight pull out, maybe jiggle a little. Tested it just then just for you
                        Bora gone
                        Vento VR6
                        MKIV GSW TDI
                        7P Touareg TDI
                          brilliant, thanks mate! I'll try it today
