Brake Pads replacement - DIY ?
  • Brake Pads replacement - DIY ?
    Hi Guys,
    Recently purchased a MK4 - it looks / feels like brake pads and maybe rotors will need replacing soon.
    Just wanted your views that with ABS in the modern cars is this a job a handy DIY'er can do. Ive done this so many times with a MK1 and datsuns etc when i was a lot younger and dont mind having a go at this - would appreciate any insight or advice if there is anything more sinister in this job nowadays
    Shouldn't be a problem i think. The abs is just a sensor at the back and doesn't interfere with the pads.Only thing that might be different are wear indicators which is just a connector to disconnect. I would say if you've done it before you should be fine.
    Heres a manual should you need it.
    1999-2005 Volkswagen Jetta, Golf, GTI Service Manual | Free PDF Download
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
      I've recently done a full rotor and pad change on my MKIV, fronts are an easy job, as mentioned you need to deal with the wear indicators if the new pads are non genuine.
      The rears will require a tool (either make like I did or buy) to push back the pistons in the calipers as they need to be pushed and turned at the same time.
      2010 90TSI Manual / Comfort Pack / United Grey
      RICE - Leave the useless wings to the Penguins...
        If it's the feel of the brakes, a bleed may fix the problem without new parts.
          thanks guys - appreciate the advice - will give it a go
          Rgds
            Yes, I learned of this the hard way when putting the EBC greenstuffs on...
            -DIDZ
