I got one sitting in my boot ready to go on. Ill get a pic of it when I get home tomorrow arv
Project Hairdresser car DIY build has begun...
'96 Mirage Track car: BC RM Coilovers, 294mm Galant VR4 Brakes, 5 stud conversion, 16x8 Forged Rays MS01S, UR 23mm sway bar, UR Strut Braces, Evo 5 Recaros, MR Lancer electrics interior conversion, Engine + Exhaust in the works
I have one. think the same model as what you are chasing. I will try to find a picture.
It goes under the drive shaft, rather then over like the stock.
cheers, does it mount with new drop links, shorter ones??
i am wanting that solid turn in feeling back
Mounts with stocks. Dont know if it was just mine, but i cracked the stock links. If anything you'd want to go longer links. as if you went shorter, the bend in the bar would touch your control arms (think control arm is the right name...)
Link
Here are some pictures of mine i found. Hope they help
I should be pulling the wheels off to add some new end links soon so i can try and get a better shot if you like?
There are two shots where im trying to compare how the drive shafts moves forward as the car goes lower
where did u purchase the white line sway bars from?
I got mine direct. A few people on here have said they managed to get them cheaper then direct by saving on postage and getting it locally.
I found my local 'middle man' was putting massive mark ups on and couldnt say how long it would take to get them
