Not getting much input on my thread in the wheels and suspension forum so putting it here as well!
I really want to do something to improve the ride of my Bora V5, it is all a bit loose and wallowy at the moment.
I am going to get the ECS Stage 2 refresh kit so hopefully that will help the numb steering feel.
With my previous car (Nissan X-Trail) I had Koni adjustable shocks and a whiteline rear swaybar fitted and the transformation of the handling was amazing even on stock springs. The ability to adjust the damping on an SUV was perfect and when firmed up it really reduced body roll and dive under braking.
Based on that previous experience I am thinking that with the Bora I will do something similar, adjustable shocks are overkill though as I won't need to change handling characteristics. Also I can't lower it as the front already just scrapes a little as I enter my underground parking, any lower and I would rip the front off.
So, if I am looking to just replace the shocks for something with more damping to firm up the ride a little, what would you recommend? The only experience I have is with Koni.
Regarding sway bars, my understanding is that if a car understeers adding a stiffer rear bar will correct that, if it oversteers adding a stiffer front bar will correct that. With the Bora I think it is inclined to understeer, hard to tell as the ESC cuts in! In which case a stiffer rear bar would help to sharpen the steering. Does this sound right?
Oh and new wheels & tyres will be on the cards at some point, will be looking to go 17/18" with around a 225 or 235 tyre, so that will help handling too but this is some way off.
Thanks,
Adam
Thanks,
Adam
