Buying a Bora 4motion..help?
  • #16
    Hmm i'm not sure but the dealer said that mine has sports shocks on it and its lowered a fair amount so much that it bottoms out on a fair bit so im not sure if its the stock sports or some after market ones
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    • #17
      Talk to Frank at orange tuning in Germany about supersport springs.
      Had 'em on my bora for 8 months now and no complaints at all.
      cost about 300 from memory
      • #18
        be after market, dont think there was such think as 'sports suspension' in the boras
        Bora gone
        Vento VR6
        MKIV GSW TDI
        7P Touareg TDI
        • #19
          Correct me if im wrong, but I was under the impression the 4motions had the sports suspension.
          I fail to see how this can be true, and also be described as soft
          "Straight roads are for fast cars, twisty roads are for fast drivers"
          • #20
            I have a Hybrid setup of Bilstein B8 struts and Mk4 R32 Springs. The springs are Euro spec and therefore are slightly firmer than the Aussie/US Spec that R32's were sold here with...
            Overall, a very compliant ride, no crashing or bouncing over undulations. The other strong suggestion is for uprated sways, I have gone with Neuspeed 21mm solid bars front and rear, and it seems very balanced through the twisties, most recently confirmed in a run thru Jenolan Caves Road .
            '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
            • #21
              Originally posted by Jaydnisevil View Post
              Well yes there is a difference, but has anybody compared it on a dyno?
              Jaydnisevil, I have Custom Code flashed my Bora 4mo and with a K&N Panel filter fitted, it dyno'ed a 127fwkw which I was very impressed about, given a Mk4 R32 owner recently posted a mid 130's kw run.
              Yea I looked at the touring kits, I would definitely prefer to get than than just the springs (Easier to install aswell!)
              I am concerned that the H&R website says they only offer springs and swaybars for the 4motion.
              Word of caution - the Bora 4mo was never sold in the US, so stay away from any of the Bora listed coilover, strut/coil kits or swaybars. Those will only suit FWD boras like our 2.0L and V5 models. If you are hunting prices/kits from US sites then always refer to either Mk4 R32 or Audi Mk 1 TT quattro..
              • #22
                Thanks for all your help guys, much appreciated.
                How did you dyno 127 fwkw when its an AWD car? lol
                I am interested in purchasing a reflash after I have the suspension sorted
                Yea I figured as such, so we have the same suspension setup as the R32 and TTQ?
                Ohh and does anybody know what rims these are?
                They dont like quite like the sport rims.
                • #23
                  Quite easy, drive the car on a 4WD dyno and discover your Haldex Controller is F'ed Another way is to remove the appropriate Relay under the bonnet...
                  http://i201.photobucket.com/albums/a...cture089-2.jpg
                  They are something of a Audi RS6 / S-line rim. I almost got a set for my Bora last year, theres a Tyre shop in Richmond, Vic that stocks them.. they have a store on eBay and yes, they are available in 5x100!
                  • #24
                    jaydnisevil A friend in Canberra is selling this kit still, might be of interest??
                    • #25
                      Haha It sounds expensive, I just dont see the point of removing the relay..Its not giving you a realistic value
                      Cheers thanks!
                      I was thinking those or RS4 rims
                      Haha ill get the car first
                      All my moneys going towards that for now
                      • #26
                        The haldex system by it's nature doesn't dyno well. It's essentially FWD and transmits power to the back when slip is detected at the front. This makes for odd readings on a lot of 4wd dynos. Pulling the haldex fuse is quick way of disabling it. You need to have a way of clearing the faults codes it will create.
                        • #27
                          Its depressing, there is only 1 bora for sale under 100,000kms for sale in VIC.. And its side bolster has been molested by some fatty...
                          • #28
                            Not always the worst thing to be over 100,000k's, if its under, you're more than likely going to need to do the timing belt, and on these cars, really not a cheap endeavour.
                            The Weitecs are a good kit, I've just ordered a set of weitec coilovers from the UK for my gti.
                            Project Hairdresser car DIY build has begun...
                            '96 Mirage Track car: BC RM Coilovers, 294mm Galant VR4 Brakes, 5 stud conversion, 16x8 Forged Rays MS01S, UR 23mm sway bar, UR Strut Braces, Evo 5 Recaros, MR Lancer electrics interior conversion, Engine + Exhaust in the works
                            • #29
                              As far as I'm aware the V6 and the V5 both have timing chains not belts. The service manual for my v5 says only to inspect the chain every 60,000kms, no replacement is mentioned in any of the service intervals and my mechanic told me it doesnt need replacing unless it becomes noisy
                              2004 V5 Bora ~ Eibach Pro + Bilstein B8 ~ Tyrol Brake Upgrade
                              MY15 Golf Wagon Comfortline
                              • #30
                                v6's got timing chain. should be replaced every 250000k's or so
                                '01 VW Bora V6 4motion - gone
                                17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
