Bora radio antenna Change
  • Bora radio antenna Change
    Hi,
    I was wondering if anyone has changed the antenna on their bora. I don't like the large stick type and would think that a bmw type fin would look a bit better. Has anyone changed theres or has any suggestions.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    yes. you can either change the whole piece, or keep the base and put a stubbie stick on top (this is more popular id guess) think you can get them from Dub Addiction.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
      There is a good writeup here on how to swap the antenna out for a shark fin style one:
      Let us know how you go with it!
      (i think the fin style antennas can be bought for about $80-$100 or something, but make sure to get one which actually works and isnt just for looks! Depending on if you have GPS in the car, this may need to be connected when attaching the new antenna)
      MkIV Bora [SOLD]
      MkV GTI PIRELLI
        You can get the stubby arial shown in that thread for $30 ish. Just screws on to replace the whip style (25cm ish) OEM.
        Stubby is MUCH shorter, I have a photo somewhere comparing the two.
          while where on the topic does anyone know of one to pick up tv signals? My headunit has so many options iv never looked into, all i needed was a aerial that supports TV signals as far as im aware
          Bora gone
          Vento VR6
          MKIV GSW TDI
          7P Touareg TDI
            Is the stubby one OEM? What looks better in your guys opinion. I quite like the idea of the shark fin but the stubby one is much cheaper and easier.
              I think a sharkfin can look really good, the one in that DIY does not look the best.
              the stubby ones take litterally 20 seconds to change. There have been some concerns voiced about the reception quality of local aftermarket ones, I got one from ebay UK for less than $30 which is supposedly OEM.
                The really short ones have trouble with AM reception if that's an issue for you. Mine's kinda half way between a stubby and the full whip, and I think looks good (I personally found the stubby looked too short for my liking).
                Nothing to see here...
                  Got any pictures i could see. And no not really mostly FM.
                  Im kinda tossing up between the two. I like the shark fins for the look but its going to be a bit more of a pain to do but shouldn't be that much of a hassle however if the stubby ones dont look too bad it would be easier and cheaper to install.
                  I was thinking of buying a double din headunit aswell with tv and all that so does that require a seperate antenna?
                    Has anyone had tried these? It doesnt look too bad i guess not sure how it will look on the car tho.
                    The VG Shark Fin Antenna by Visual Garage was the first aftermarket shark fin antenna designed for car enthusiasts.  It is the ideal modification because the antenna is both stylish and functional.  With a unique design and shape that is both trendy and upscale, the VG Shark Fin Antenna blends into the vehicle making it look like it came pre-installed from the manufacturer. As the pioneer in aftermarket shark fin antennas, the VG Shark Fin Antenna not only looks good but also receives AM/FM reception while allowing your integrated satellite radio, GPS and navigation antennas to function properly.  We custom paint every order to match the OEM color code of your vehicle to ensure that the shark fin antenna blends in perfectly.  Installation only takes minutes, which means you’ll be up and running in no time. Visual Garage Inc. was created with the goal in mind to deliver quality products and outstanding customer service to car enthusiasts worldwide.  Come and take a look at what we have to offer and feel free to connect with us at any time! Select Your Vehicle Manufacturer Below or View Complete Car List Here If you can't find your vehicle, or if your color code and paint name isn't listed, please contact us and we'll be glad to help!
                      anyone have any suggestions or know if this effects the reception
