In the last couple of days i've heard a strange whistle sound when boost gets to 10psi and over (i'm chipped and it will boost up to 17-18ish)
I was thinking it sounded like a small boost leak escaping out of a small hole sort of sound, hence the whistle...
the car still seems to boost fine, though hard to say. but it seems maybe a tad slower.
so the question is, can you have a boost leak, and still get to your top boost pressure?
the way i see it, say you boost up to 18psi, couldn't the turbo still boost the pressure up that high, and all that you're loosing is flowrate, rather than pressure, i.e most goes through the throttle body, with a bit leaking out a tear or bad seal.
of course this would depend on how bad the leak is i suppose...
the sound is predominantly to the right side of the car (windows open) as you'd expect... i can't hear a vacuum leak at idle...
the sound is basically the sound of the normal airy turbo spool up sound, but just with a subtle whistle... not sure what to do about it!
