I've had this warning light flash up on me twice in say the last 6 months, but it goes away very quickly, almost too quick to read even. both times it showed up just after had taken off in the car.
now i've not started my car for two weeks, and i go to start it, it turned over and the engine started but then the engine stalled after a second or two.
subsequent attempts the starter motor appears to be working but the engine doesn't start. i tried jump starting it but with no luck, i tried doing so with the other car running for a while with no luck, and then i tried with both cars off but with the batteries connected for a good 20 min, no luck. it shows about 12.7 volts across the battery terminals (not sure what it shows when trying to start it)
anyway i've just joined nrma roadside assist, and can't call them for 48 hours or you gotta pay them $160...
are these two things related?
a bit more info, i've had it a couple times in the last 6 odd months where it has taken several turns of the key to start the engine. so i don't know if the alternator is going, or if the battery is going etc.
anway NRMA will hopefully sort it out shortly, but in the meantime, anyone have any ideas?
cheers
cheers
