what year golf/bora do you have?
windows up/down on key remote
Originally posted by fuzion View PostIf you can get the key blade cut again, use your existing transponder chip into a new keyfob you can get a flipkey for your 03 quite easily yes.
I don't have a remote transponder key. I want to know if that was an optional extra or standard on the Golf 03 SE. If it's standard, then the loser who owned my car before me has lost it and replaced it with a dumb key. (cheaper option)
If it was not standard, that means that more than likely my car hasn't got a remote locking system. However, I'd still like to find out if there's a way I can prove it. I don't consider the type of key I have to be definitive proof. Anything could have happened under previous ownership, and proof of that is shown by the fact that my boot is keyed differently! Deifinitely something dodgy going on there.
Sorry if I didn't make myself clear earlier, I look forward to some enlightenment on my situation. The missus it bitching that she has to turn a key to get into a 2003 European car, and I can't say I blame her!
Cheers,
Sherwy.
Originally posted by Sherwy View PostGuys, I don't mean to sound ungrateful but if you read my original post, #8 just up there, everything I want to know and all my information is laid out there.
Cheers,
Sherwy.
If you have a 02+ you have the flipkey as an option. He may of lost or broken or damaged the previous keys. A replacement coded/programmed from vw is close to $600 almost i think still these days hence he probably took the cheaper option or got it done elsewhere or for half the price of the keyfob.
Your key looks like so
(with or without the logo correct?)
You can get this key
internal
and the second part
So what you can do is, inside your KEY has a transponder chip (probably easiest thing to call ti for you)
If you get a new BLADE for the flip key cut, get a pair of tweezers, take out your transponder chip move it to the new flip key. Get the second part of the key and program it to your car to unlock and lock you will then have least 1 flipkey for substancially less then what you would pay from a dealer.
Does that make sense?
So YES you can get a flip key.What’s behind you doesn’t matter..
In the boot on the side of the spare wheel well there is a huge sticker with codes on it.
Each of the codes represents the options that were on the car when it left the factory.
Enter each code on this page -> http://igorweb.org/equidec/
Search each of these codes to see if remote locking is listed. That should tell you what's in the car.
If it comes up with central locking you can then look into getting a new remote for it.MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Originally posted by Bumpknuck View Postcan you hook this up on my car or did someone do it for you?
VChecker plugs into the console port under the aircon controls etc on a MK IV, same as VAGCOM.'03 BMP MkIV Golf GTI | Oettinger tune | K04 | 18" OZ
'04 BMP MkIV R32 #144
search getnew
Thanks Just Cruisin and Fuzion, very helpful posts there. Ok the only mention I can see in all those codes is "4F1 = Central locking system".
So I take that to mean I have central locking only and no Remote locking/immobiliser?
They keys I have look exactly the same as the small one in the photo that Fuzion posted, however they do not have transponders in them, only a light.
So it looks to me as though remote central / immobiliser was an option for this model, not standard. That being said, is it possible to upgrade, either using a genuine VW system or aftermarket?
Cheers,
Sherwy.
Originally posted by fuzion View PostSherwy, i read what you said i was asking you clearly exactly what.
internal
and the second part
YOU can get a flipkey remote, you need the following parts as mentioned above and this will work for you.What’s behind you doesn’t matter..
If you have Central locking with radio remote control, interior locking & "safe" securing system (i.e. door LED) then the code on the boot sticker is 4K3
You would at least need to retrofit the proper Comfort Control Module with the radio receiver inside it.PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
Fuzion, I'm confused by your comments. I never asked for a flip key. Is a flip key the ONLY way to get remote unlock/immobiliser? ie Does it have inside it the necessary hardware to do this?
I've just opened up my key again, I think I MAY have found the transponder chip. Is it a tiny little glass capsule with no wiring attached? It's underneath a grey rubber plug on the opposite side to the light bulb.
Cheers,
Pete.Last edited by Sherwy; 14-12-2009, 12:53 PM.
Thanks Graeme86,
very helpful. I figured that would be the case and I'm guessing that will probably cost a packet. I'm guessing aftermarkets stuff could be a lot of frigging around too.... back to the old internets for some research!
Cheers,
Pete.
Originally posted by JustCruisn View PostIn the boot on the side of the spare wheel well there is a huge sticker with codes on it.
Cheers,
Sherwy.
i have 4F1 = Central locking system, does this mean i cant just do the blade and transponder swap into a flip key remote?rikard's dating faux pas #067 - "hey i had a really great time tonight, i feel like i owe u something ..would u take $20?"
