difference with AGU and AWP turbo inlet hose
You need to get the one listed for your engine as VW moved the DV and some of the other connections about.
GAvin
Originally posted by gpk_gtiso am I to understand that basically its the same just bits have been moved???
my 02 model is a AGU. just on the left side near the rad bottle you can see an imprint of what it is if im right..
i just chucked my forge tip in yesterday actually, i advise if you dont know what your doing set aside a day for it. check vortex faq for instructions, much easier that way around.
think will be bringing more Forge TIPs next month, along with other branded TIP's as well. 10-25% off rrp too.What’s behind you doesn’t matter..
The engine code will be on the sticker in the service book or on the head I think, front left corner, you might have to take the cover off. If it has a cable throttle on drive by wire it's highly likely that it is an AGU.
I don't think it's an all day job but certainly not a walk in the park either. Mine was a bitch to fit and even though it should have fitted the AGU it didn't fit perfectly and I had to do a bit of modification to the DV takeoff.
