If the car still starts and runs I call bullshait .
If the MAF , Throttle body and lambda probe are dead there is no engine to ecu inputs . How much fuel / timing does the ecu give if all it has is a crank angle sensor to tell it the position of the crank to the cams the coolant temperature and the outside air temp !!!!
ok! the car does run (roughly)and starts normally! however the mechanic said should not drive anymore till fixed??beacuse of quoted problems?? he said he put it on the vag-scan. how are we suppose to believe??getting that feeling im getting done over?!
just let everyone know on what problem was with my car:
was running on 2 cyl., the MAF has died?, oxygen sensor needs replacing, coilpacks gone, spark plugs fowled and need another throttle body?? (this is what mechanic told me) and just to top it off when i got to mechanic the driver window just crunched and died??
im just wondwering what could cause such problems??
always used premium fuel never thrashed car always been serviced!?
anyhow there you go!
I have to call BS on that. Way too many problems occuring simulateously.
Who is your mechanic?
02 sensors, MAFS and coilpacks are common problems, but you'd have to have incredibly bad luck for them to all go out at the same time!
See if you can get it out to Seb somehow, even if it's on a flatbed.
ouch! mechanics certainly do have you by the short and curlies sometimes dont they. They are the experts and we are forced to trust them. Hopefully they dont take advantage of us toooo often.
If you can't diagnose a fault by using your experience and 5 senses, then it's a process of elimination. This is a scientific rationale whereby one variable is tested at a time. If your "mechanic" simply replaces everything that could be wrong, find a new mechanic. No, they don't have you by the short and curlies because there are lots and lots of good workshops out there if you're prepared to spend the time shopping around. We're lucky on this forum because we have some very experienced and knowledgeable members who have VW workshops and will always look after our users by doing the right thing. Go to one of them
aarrrggghhhh!!!! SIMON!!! you should have taken where I said!! I had same prob early last year.maf died.cost me $780 to fix. doubt is was your coilpacks too. you got ripped.did you take back your old parts???
