Driving home thisarvo and car seemed not as smooth as normal but still drove fine.Herd a few quite clunks but nothing over the top so when i pulled up at home and had a quick inspection under the car i found a nice puddle of fluid ?
I have a cold at the moment and could not work out if it was brake fluid or gear box oil, got the car up off the ground so i could check things out n removed the air box to have a look at the gearbox more clearly and i discovered that there was alot of fluid arround the top near the clutch slave unit.
I had trouble with the slave in the past so cleaned up the area and pumped the clutch a few times and hey presto some fluid leaked out.
BUT
A mate came by n had a smell and told me its gearbox oil and the sheer size of the trail of liquid up my drive way leads me to belive that he is correct.
I have just spent 2 hours trying to find where this oil has come from and have no idea.
it seems to be comming from the top of the box arround the clutch slave and dripping down the back then all along the underside of the car???
I know people have issues with these boxes so any pointers on what i should be looking for.
P.S. Its an O2J with a peliquin LSD
BUT
But what leads me to think its oil is that the brake fluid isnt overly low compared to the amount of fluid on the drive way.
and gearbox was working fine befor i knew it was leaking and after (reversed it out of the garage and drove it back in with No clunks, ticks or flamboyant sounds of death)
