Hi all,
I have also posted this in the audio section, but thought being model specific, i might have a better chance of a solution from all you MkIV owners
Just after some advice regarding a problem with my stereo. I have a pioneer head unit, standard door speakers and a pioneer 12" sub.
Initially thought this was an issue due to my car not having an antenna when I bought it, but putting an antenna on hasn't fixed the problem.
When i'm listening to a CD or aux input, the sound is fine, crystal clear. The reception of FM band is clear also, I cannot fault it at all. Recently i have started to listen to the AM band more frequently, but when I'm driving it's near impossible to get a clear signal.
The symptoms of the problem are as follows:
*Reception fine when ignition is at the ACC position.
*Ignition turned to on, will get rythmic pops but the reception is still fine.
*Started engine, reception is over-run with static and the radio now transmits the sound of the engine.
*It's through all speakers, the only speaker hooked up to the amp is the sub.
This is really bloody annoying, especially during the recent bushfire season when I couldn't get any info from ABC local radio.
Things I have tryed to fix it:
*New antenna.
*Disconnected amp and sub.
*Cleaned amp earth point.
*Connected a little black box that was on the head unit i took out which i think MIGHT be a noise filter..
Thanks for any and all help.
Gav
*New antenna.
Gav
