Camber adjustment on lowered mk4's
  • #16
    Yeah that will be very noticeable to look at. Pics will show that for sure, cant really see where they can go wrong?? When you say you had it lowered, did you use brand new stuff???? There is a minor camber adjustment for the front which is by moving the subframe. Doesnt do too much though. Adjusting the rear is a pain. Even 2degrees is a getting there
    Alba European
    • #17
      OK, so I just got the car back (they ended up having to keep it overnight)... The numbers tell the story more than the pics, its quite hard to capture on camera... Rear has approx 3.4 degrees of negative camber, and 1.7mm of toe-in, so I'm guessing new tyres will be in order in about a week!
      The guys at Pedders are going to try and get hold of some adjustable upper control arms to fix it, so will let you know how I go...
      Nada as yet... But working on it...
      • #18
        you do know neuspeed,forge,black forest ind, all make the upper adj arms.
        mk4 the mods begin for round 2 hahahha
        • #19
          thanks Dub20v, no i didn't know that actually, thanks. will check em out...
          • #20
            Sure does show in the piccies mate
            Good luck with that
            Jmac
            Alba European
