Took my car in for a wheel alignment today and the mechanic informed me that something is knocking on the shaft between the cv joint and the gear box on the drivers side. When i purchased the car 3 months ago it already had pedders sports rider shocks and lowered springs fitted. I have noticed a knock every now and then when you hit a large bump but i just thought it was the bump stops. Anyone got and idea of what it could be?
Something hitting shaft between CV and gear box
Originally posted by gtimk5 View PostThe driveshaft can hit the swaybar if its pretty low.
Originally posted by onevan View PostYeah probably have a look at it before it hits the gear box and punches a hole through it..., and the longer links are crap much better off with a proper swaybar with the extra clearance, i tryed the longer like with my old gti and found its just the small bend it the std swaybar is way to tight, get a H&R or neuspeed or a whiteline
mk4 the mods begin for round 2 hahahha
Originally posted by DUB 20V View Postum it wont, the sway bar cant put a hole in the gearbox, and the longer links are crap much better off with a proper swaybar with the extra clearance, i tryed the longer like with my old gti and found its just the small bend it the std swaybar is way to tight, get a H&R or neuspeed or a whiteline
