Bora R32 Build Thread
  • #16
    I really struggle to get why insurance companies make cars like this a stat right off. Yes it needs some work, but nothing structural! why make it impossible to re-register if someone is willing to repair it properly.
    That said, I'd love to get hold a wrecked one and do the same as you Beale, my V6 4mo has all the r32 kit minus the engine, looking forward to the updates.
    • #17
      Originally posted by RolfGolf View Post
      PS. Great looking wheels - what do they weigh? Should look fantastic with a refurb.
      So the Aristo's with rubber were about 20.8kg.
      The RZ's with rubber came in at about 24kg!
      Definitely will not be fitting these until my suspension is done. They need a refurb anyways, luckily it's minor rashing around the lip only.
      2004 VW Bora 4motion | 3.2 Swapped - R32 Trimmings | BBS CH | Forever fixing this bitch
      • #18
        Originally posted by jmcc View Post
        Nice!! Are you going to bring them back to the stock colour?
        Originally I thought I'd keep them black but changed my mind after seeing up close. So I'm tossing up between stock or gunmetal, like the set Hawk had recently pictured below.
        • #19
          If the same vehicle was registered in another state it would have been listed as a "repairable write off (RWO)" and could have been re-registered. It's just our NSW state laws here that prevent it. Worked out nicely for me I was able to pick it up cheaper than if it had a RWO status. Next year these R32's will have no WOVR applicable as they'll be +15yrs old so potentially they could all go back on the road.
          In this case, I think from memory some of the parts were unavailable or uneconomical to wait for. (E.g. replacement bar cover 8-12week wait from Germany, meanwhile the owner is driving a hire car at $30-$40 a day) Sometimes it's just not the actual cost of repairs that kills it but other factors.
          • #20
            How do you find the R32 shocks and springs Gez? I'm tossing up between running R32 gear or coilovers (purely from a pricing point)
            It's my daily drive so I don't really need anything crazy low or adjustable... well not yet anyways.
            • #21
              I think they're a good improvement over the standard Bora 4mo shocks and springs. You get a very slight ride height drop but a firmer, less bouncy, ride. Given you've got everything you need, i'd go for it. Very easy to do, just drop the entire front sub frame including the front struts.
              • #22
                Thanks Gez, that sounds like exactly what I'm after. Firmer, with a little drop. I'll be changing any bushes/mounts as I could my only concern is the shocks/spring from this R32 have done about 150,000kms. Which is not bad, but it's certainly not great given everything else will be new.
                • #23
                  And then there was one... donor Bora has left the building. Spent the weekend playing muscial rims and reclaiming my yard and shed.
                  • #24
                    They should be ok, it really depends how the car has be driven. Mine had done 80k when I fitted them, 20k later they're still fine. My stock 4mo shocks had done 240k and where still ok.
                    • #25
                      [ATTACH=CONFIG]33599[/ATTACH]
                      Yeah that's a pretty nice colour, I think it'll look cool
                      2002 Golf GTI - K03S | 3" Downpipe | 312mm DBA T3 Slotted with Forza Pads | | Forge 008 | Forge Hoses | ECS Performance Mounts | R32 and Urethane Bushings | Pipercross Filter | Sachs VR6 Clutch with 14lb Balanced Flywheel
                      • #26
                        Will soon be time for some extreme head porting ...
                        YouTube
                        • #27
                          YouTube
                          holy ****, I was thinking how extreme could it be.... well.. I was wrong
                          • #28
                            YouTube
                            That's a serious head job... (Oh c'mon someone had to say it!)
                            • #29
                              So before the donor Bora left my place I had the chance to pull the heatshield and exhaust off. 3'' BBE (BillyBoat Exhausts) stainless steel mated to a Magnaflow muffler with twin R32 style Xforce tips.
                              It was obvious this thing had been running on the dirty roads and was in need of some love.
                              Before:
                              After:
                              Having never heard of BBE I probably wouldn't never have bought one (bit of goofy name too, BillyBoat?) but after seeing the product up close it's definitely the business. The welds are beautiful
                              BBE
                              I also noticed from the donor Bora the previous owner did a bit of hack job on the heat shield to clear the larger pipe so whilst I had all the gear out I tied that up as well.
                              • #30
                                I literally found myself watching about half a dozen of their videos - the work is stunning and the use of dimpling to improve airflow is just next level.
                                Classic!
                                That exhaust came up a treat - was it just metal polish you used? Looks fantastic. It's just so satisfying when you start with something that looks like a piece of scrap and achieve results like that!
