Timing Belt Change Help needed urgent
  • Timing Belt Change Help needed urgent
    Hey guys, replacing my timing belt today and I bumped the gear when removing the belt, now out of time any help in regards to aligning crank, cam and Distributor drive would be much appreciated
    Thanks in advance,
    Rohan.
    Sent from my ONEPLUS A3010 using Tapatalk
    Hyundai Getz (2015 -- 2017)
    Golf Mk3 GL 95' (2017 - 2018 - Now)
    Golf MK2 GTi 91' (2018 - Now)
    It should have a dot on the distributor gear, that lines up with something else.
    However, chances are someone has half-arsed it in the past and the distributor will be out of time when you line the marks up.
    Or... If the motor is at TDC, pull the distributor cap off, and turn the gear until #1 is lined up at the rotor button.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      Google is your friend. I just did a quick search and it brought up a video which on my iPad was not the best in quality but it shows you in good detail how to line up the distributor mark with the marks on the other pulleys. You might have to do some cleaning and grab a whiteout pen or similar to make it easier to see.
        Thsnks for all the replies, I ended up setting the timing manually by matching up all the TDC marks, used a screwdriver to test when the piston was at its highest point, lined it all up tried to start and it wouldnt, dizzy was out by one cylinder so fixed that up and its running now, still a bit rough but genuinely better than before the new belt.
        Thanks ks for the replies.
        Rohan
