Yep, the dreaded coilpack failure hit me recently, and to cut a long story short, I've been able to source a second-hand one, with one terminal boot broken off, for $100. With the aid of a terminal boot off my busted coilpack, and some JB Weld from K-Mart, I'm in the process of reconditioning it and will post pix once it's all done =)
Here's the full story:
OK, So I thought that it would be nice and easy to repair any hairline cracks in the coilpack with some high-temperature silicone sealant.
I knew from experience that taking the coil-pack off would be nice and easy. Unplug the ignition leads, undo 4 hex-head bolts and unclip the wiring loom.
Pulled off the top three ignition leads, no problems. Went for the second row, and as I pulled off #1 - the whole freaking plug came off the coil pack!
Holy shoddy-workmanship, Batman!
The pack I have is the Beru one and it's lasted 100,000km, but seriously, the epoxy cracked so badly that the plug just came right off!
What's more, it seems that the inside is filled with expanding foam or something like that, as now there's hard foam over the bits, and I can't even fit the broken piece back onto the coilpack - it simply doesn't go! I can't even see the metal contacts that would be carrying the current!
Now I'm left with two alternatives - this one looks like it's beyond repair, I can hack one together with a $20 ford coilpack off eBay, or I can call wreckers around Melbourne and see if anyone's got one.
From what I've read, the Golf VR6 is even more rare a beast than the R32. We had 200 R32s imported, and one source said that we only got 150 or so Golf VR6s - so I don't like my chances of finding a broken one (the Golf that is, not the coilpack!)
Grrrr!
Grrrr!
