Hi there.
Hoping someone can help me out with an issue. I have a MK3 Golf GL (1997). The story is..
1. My battery died a couple of days ago (battery dead, would not turn over the engine), so I swapped in a old spare battery i had to get me by, which worked ok.
2. Bought a new battery today and put that in, but then car will not start, spins engine over easily but engine not fire.
3. Put old spare battery back in, same issue engine turns over but not firing.
4. But new battery back in, same issue, so i have concluded this is a new issue, must be con-incidence?
5. Started troubleshooting...
a. check all fuses i could find under steering wheel and 1 i found in engine bay, all good.
b. took out spark plug and checked if spark, no spark..
c. followed some troubleshooting from service manual to test the coil and "power output stage"
test-1. disconnect 3 pin connector from coil and test current across pin-1 and pin-3 with ignition on, current is there, test passed.
test-2. connect test-light across pin-2 and pin-3, turn over engine, should see test-light flash, test failed, i don’t see any flashing or light at all. My manual says if this test fails then -> The ignition ground signal from the ECM is missing, check the wire between the ECM and the coil output stage, if not wiring faults, then ECM may be faulty, and should further test the ECM.
I am not really confident in testing the ECM so i skipped that testing, and went on to next test.
test-3. remove small cover from coil terminals, connect test-light, turn on ignition and check light comes on, it did test passed.. Then turn over engine and check light flashes, test failed, light did not flash.
From the 2 tests above i think maybe ECM is not sending the pulses of electricity thru to the coil, does this should correct, do i need to replace whole ECM or could this behaviour be caused by something else.
any tips or thoughts appreciated, otherwise i be off to auto-electrician tomorrow i guess.
thanks in advance
Kim
thanks in advance
Kim
