So I sat down and read a bit. From these findings, the clutch itself should be okay. Seems the end of the clutch cable has loosened from it's metal plate.
The last months, since May or so, there have been intermittent vibrations upon clutching into first gear from standing still on low rpms. There hasn't been any slip from the clutch on heavy load, and the cluth works fine for about two weeks intermittently, before having the jitters for a few days. Maybe that has shaken things loose?
I guess I could try and loosen the cable, if it turns out I have a manual adjuster, and then reconnect it, if I can find the metal plate for it to slide into. Is it hard to come by?
