hey all, i have recently bought a 94 vr and found it running quite poorly on the drive home after picking it up (misfiring, sluggish from a set of lights etc) owner claims the plugs have been replaced which by the looks of them they have (good quality plugs too) but cylinder 3,4 the leads are real loose and wont clip properly down unlike the others, as i ran the car in the dark the two cylinders (3,4) would arc quite badly/often. question is, should i fork out for a whole new set of leads due the the two of which dont sit tightly over the plugs? or is there something else i should look for.. thanks in advance.
(vr6) arcing against block...
Check where it's arcing from in the dark. From what you've said it's probably coming from where those leads are loose. If the lead is loose you'll be able to see it arcing from where it connects to the coilpack or spark plugs. If it's arcing from the coilpack, take it off and inspect it for cracks.
If the coilpack is cracked, easiest/cheapest thing to do is the JB weld epoxy fix:
If it is the leads, just buy a full set. No point in having some old/some new for the sake of $100. Make sure you get an ignition lead removal tool or make something similar to remove/replace the ignition lead from the spark plug: Techtonics Spark Plug Wire Removal Tool, Mk3/4 2.0L, 12v VR6 [945 000T] - $35.00 : Techtonics Tuning, VW and Audi Performance Tuning and Repair Parts
They are a pain in the ass to access and pulling on the lead will break them!'95 Golf VR6 Colour Concept
