Blue tooth OBD2 Elm327 device
  • Blue tooth OBD2 Elm327 device
    Hi all,
    I have read loads and a lot of conflicting info.
    Question:
    Is anyone using one of these to an phone app on a mk3 golf with success. I firmly belive my 1996 vr6 is obd2?
    1996 VR6 Golf
    Yeah it will connect and show stuff like rpm, speed, temp etc. It won't be able to check error codes though, mine cant.
    I have a little handheld vag code scanner for that though.
      By firmly believe you checked the engine build date stamped in the engine bay?
      I thought mine was '96 too because that's what the car was registered as. Turned out it was built in '95.
      Do you have square side indicators?
      I bought the same tool for mine and it didn't work, couldn't connect to ECU, used the Android App Torque.
      Mine is OBD1 and had to use VAG-COM. By the way VAG-COM is really good and about the same price but BYO laptop.
      Past - '95 VW Golf MK3 VR6
        Thank you all. I have ovel indicators and stamped 1/1/96
        1996 VR6 Golf
          Oval indicators and a build date of '96 indicate that you should have OBD2.
