ABS light on dash
  • ABS light on dash
    Any of you guys had your abs light come up?
    happened recently while driving on the high way,
    hasnt seemed to affect the car at all..
    i had the same thing happen to my bmw a while ago but the ABS still worked.
    should i bring it into someone to check for fault codes?
    car is an AAA 94' Vr6 mk3
    cheers,
    ABS units usually go mate. Lucky if its an abs sensor but unlikely, even if it is throwing that car. Worth a shot cleaning them all up though!
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
      are the units just plug in? i might hace a spare in my part donor car.
      cheers for the input.
        Depends on the vintage man. The OBD2s and some OBD1s have different style units to the early OBD1s. I know that when I did a direct swap between my 1997 wreck and my 1996 build car it worked straight away so you could be in luck!
        The issue is that the solder joints dry out and crack in the unit I think, so if you are daring you could always try pulling it apart and resoldering it?
          It could also be the solder joints in the abs module. I had every single abs fault possible. Took the module out (it attaches to underneath the abs pump) took it apart and resoldered any suspect looking connections. Works perfectly.
            Remove Black plastic dash part where ABS light is on your dash , Unplug ABS light plug , snap ABS light cover back on dash.
            Problem gone
            - VITS 2016 24th April -
            Albury nsw Search vits on FB
            @vitsvw @vdubin_
