Coolant warning light keeps flashing
  • Coolant warning light keeps flashing
    My coolant warning level keeps flashing when there's plenty of coolant in on the MK3 Tdi. I thought it was the level detector in the header bottle but an auto-sparky has blanked it out and established it's not the problem. He says it's a cluster issue, partly because my fuel level indicator goes up and down unpredictably, but I think the connections down by the tank might be at fault from when I had the fuel tank removed and cleaned.
    Any ideas?
    Mk3 Golf Tdi about to sell
    Mk 1 Golf GLD somewhere in a paddock!
    Mk1 Golf Cabriolet
    MK2 Golf Turbo diesel engine and 5 sp gearbox
    Id be trying a new coolant bottle, blanking it out hasn't worked for me in the past. If it full of coolant and you fit a new bottle which is normal process or elimination you might have a dry soldered connection on the cluster but if all else fails google it, sorry it seems to be the way we fix cars these days
    Jmac
    Alba European
      thinking out loud here.
      1. bridge the sensor, if problem continues it must be back somewhere in the circuit (probably at the cluster), not the level detector.
      2. what else is on that circuit? it may be causing it - check the fuel level indicator circuit
      3. may be a faulty dash cluster, common problem.
      find a bentley manual, it may help
        Sensor was bridged by the auto-sparky, but I am not sure what else is on the circuit, thanks for the suggestion, I'm gonna check my Haynes and see if there is something else on there.
        Mk1 Golf Cabriolet
