VR6 "cutting out" at 3500rpm on full throttle
  • VR6 "cutting out" at 3500rpm on full throttle
    Anyone ever had a similar issue? Someone mentioned there is some "anti-flog" thing that wont let you hurt you car when cold... but this is something else.
    Even when the car has been running for over 30 mins, the issue still occurs sometimes.
    If I slowly creep up the RPM, it's ok, but if I hit full throttle, it will cut out just when the car usually gets its power. If I hold my foot on the accelerator, the engine wont be running at all, and when I release my foot, the engine kicks back in.
    Any ideas?
    RIP Ruby Thunder (1994 VR6), now driving the GF's MK IV 1.6
    what have you tried so far?
    Sounds like leads or coilpack to me. Have you eliminated them?
    FOLLOW US ON FACEBOOK
      have u had it scanned for codes yet?
        Not as yet... gotta do a 400km drive tomorrow too
        And codes... hrm yeah, not too keen on taking to VW.
        It actually seems to be doing it a lot more often since I put MattyT's stock airbox in her.
          Awww just because you dont have your luvley K&N filter on it anymore
          I have no idea what might be causing it. Codes might say
            when you change the air filter back steal MattyTs ignition leads.
            If that doesnt work. Steal his coil. See if it helps
            also
            Buy one of those cheap scanners off ebay for $15. They ship direct from asia and only work with the old version of the vag-com software but it will be enough for you to scan the car if you have access to a laptop
              Did you touch any of the clamps after the MAF when you installed the airbox? You may have non-metered air sneaking through causing it to go into limp mode...
              Originally posted by Whubbsie
                Possibly... I'll check that out tonight.
                  We fiddled around with alot of stuff trying to wedge the airbox in. His freakin engine block was a few cm over to the right then mine, making it a huge hassle to get the airbox in. I'm pretty sure we even removed the MAF entirely at one point.
                  ps. dont steal mah leads n coils, dey is mine!!
                    Hey! Look over there! YOINK!
                      Check all the conections. If it ran ok before that leaves one common denominator
                      Let us know how you go...
                        Probably coilpack mate. Very common on VR6.
                          Have we established if there's a way to check this before going and purchasing lots of money's worth of replacements?
                            Try a diff coilpack methinks
                              yes. I already said that. Just butcher MattyT's car
                              ive lent my coilpack to several people to try and test for issues. Its a 5 min job to remove
