Knocking from front right corner.
  • Knocking from front right corner.
    I get a knocking sound (knock knock knock knock) from the front right wheel area when turned, doing between 80 and 100km/h and turned about 30 degrees on the wheel.
    Any ideas? Sound is there power on, power off, and braking. but if i move the wheel either side of that point, the sound goes away.
    might be a CV joint?
      Can you say broken engine mount :0
        Loose control arm ???
        MODS- TOO MANY
          mine was Tapping..loose strut mount.
            Originally posted by ScienceVR6 View Post
            I get a knocking sound (knock knock knock knock) .
            who's there? haha
            Id be checking your strut mount/rubbers
              Its had a broken engine mout since i bought the car, im wayy to poor and lazy to fix it atm. But it's never knocked like this before.
                if you leave your car too long with a broken engine mount it WILL tear off the weld that holds your subframe on
                FOLLOW US ON FACEBOOK
                  ohhhhh, i'd probly better have a look then.
                    Where would one get new engine mounts? I have a feeling one of mine is buggered!
