Question about adapters
  • Question about adapters
    Heya guys,
    so I'm looking at getting 5x100>5x120 adapters from Adaptec but am a bit stumped on which type of adapter to purchase.
    Now I know the benefits of getting hub-centric adapters but seeing as though the wheels I'll be putting onto these adapters have a large CB (72.5) would it be benefitial to also order the hub+wheel centric adapter?
    I don't want to purchase the two-piece adapters and I know I'll be ordering a 20mm thick adapter.
    thoughts?
    .:R32
    8L S3
    Mk3 VR6 - SOLD
    Flickr
    I'd you get yourself the smallest hub you can get. 57.1mm in this case. You can just use a hub ring on the wheel side, then you can use all wheels with a 120pcd and don't need to worry about machining cb's.
      That actually sounds like a smart idea Hayden! Wont be limiting myself to just 72.5CB wheels. Never thought of it that way.
      cheers
      .:R32
      8L S3
      Mk3 VR6 - SOLD
      Flickr
        Wheel and hub centric for sure.
        You only need single piece adapters for 5 to 5 stud conversions.
        What Hayden said is a good idea, as long as 57.1-72.5 rings (and other sizes you may want to run) are readily available
        Bora gone
        Vento VR6
        MKIV GSW TDI
        7P Touareg TDI
          I also have a question but its completely different,
          i want to put a set of porsche lobster claws on my mk4 r32, but I'm afraid that the adapters will **** with my performance and whatnot, i don't know anything about adapters, but I'm thinking that on the fronts, if i take a hard corner wouldn't that put a lot of stress on the longer bolts?
          Mitch
          Mk1 Gti 81 2Dr
          Mk2 Gti 88 2Dr
          Mk4 R32 04
            They are fine. I've done some severely hard driving on ****ty roads at stupid speeds never had an issue. Adaptec/H&R though are tough as.
              Use quality adapters correctly and its fine.
              No difference to using the wrong bolts or not tightening correctly on normal wheels.
              Bora gone
              Vento VR6
              MKIV GSW TDI
              7P Touareg TDI
                Mitch
                As long as the adapters are well made and are hub and wheel centric, your only problem is the increase in unsprung weight.
                Present: Mk3 Golf variant.
                  In 20mm there's enough thickness to be 57.1-57.1 hub and wheel centric that's deep enough for the longer rears, go for it.
                  SILVER '98 MKIII GOLF GL // BORBET TYPE A's
                  YELLOW '76 B1 PASSAT LS WAGON
                  WHITE '07 MKV JETTA 2.0 TFSI
                  FLICKR
                    yeah, im going with 20mm all round so I can get some crazy dish on the rears and have it somewhat flush at the front. Still have to measure up what size barrels and lips I want so yeah
                    .:R32
                    8L S3
                    Mk3 VR6 - SOLD
                    Flickr
                      There's enough in 15mm to.. I have adaptec ones that fit. Not sure what your issue was with ecs, if that was you.
                        Don't think there is for 15mm rear Hayden.
                          Never mind. On a different tangent
                            Yeah that was me, not enough material there for 15mm on the rear hubs.
                            FLICKR
                              awesome, cheers fellas
                              Mk1 Gti 81 2Dr
                              Mk2 Gti 88 2Dr
                              Mk4 R32 04
