MkIII Golf fuel light? Can one be added?
  • MkIII Golf fuel light? Can one be added?
    Driving a car without a fuel light is killing me.. I am that type of bloke that drives til the light comes on.. then drives some more.
    If you added the light from a cluster from one of our American cousins could you wire this little bad boy to work? I know the correct resistance for them etc
    Previous VW; 6n3 Polo 16v, MkIII VR6
    Current; 9n3 Polo GTI
    It's generally not a good idea to run a car that low on account of the injectors accumulating residue from the bottom of the tank. But I feel you, mk3 clusters are temperamental to say the least.
    1997 12v VR6 in Dragon Green
      the dash cluster isn't too hard to get out, you might wanna check the bulb, I changed much of my dash cluster bulbs to LED due to this. I suppose you could jump off the fuel light supply wires (in parallel), but use a very low current drawing light like an LED. Ensure the LED is the right voltage or you may have to solder in a resistor.
