Where does this belong..?
  • Where does this belong..?
    Guys,
    Found this yellow plug around where the airbox is supposed to be. I have no idea where it belongs or plugs into.
    Can anyone help?
    VW Golf MK3 VR6
    Yeah thats a spare mate for a dim/dip resistor which you do not have, just as well they were setting them on fire in the UK. Keep it spare mate.
    HAve you found that fuse yet i took some pictures of an Audi today for you to give you an idea what they look like, ive just got in from the shed so ill post it up late mate
    Alba European
      Thanks Jimmy.
      The fuse looks to have now finally stopped working so I'll need to sort it out asap.
      VW Golf MK3 VR6
        If your elecs have stopped altogether give your ign switch a tap mate , this too can cause this kind of fault, i will post this fuse in the meantime. Give that ign switch a tease in case it is breaking down too.
        Cheers ( should be easy to find now as it has packed in altogether) can you please check that fuse 14 is live with the ign on. this is where they get the ign feed mate,
        Alba European
