chassis/suspension bracing?
  • chassis/suspension bracing?
    just looking at improving the handling on the vr6 and stiffen it up a little. i haven't driven to many cars as hard as i drive the golf so i don't have much to compare the amount of chassis flex to, so i guess i was wondering how much flex there is in the mk3 chassis/suspension and if there is any one that had any bracing and how much it helped?
    I recently installed a 28mm adjustable rear sway bar and it has reduced under steer greatly. Massive improvement and highly recommend.
      To make a good handling car:
      - Good coilovers or spring/shock
      - Increase front camber
      - Sway bars front and rear
      - Lower offset and wider wheels
      - Good suspension bushes through out
