Battery, for VR6
  • Battery, for VR6
    Has been covered before, but trends, brands, etc change. I want a good trade-off between cheap but decent. Ideas on batteries, and ideally places to get my mitts on one in Brisbane (or have it posted).
    The best option I found was a HiTec from 'batterys now' for about $145. THey will all want to sell you the bigger DIN65 but I was too stingy and wanted to save the 30 bucks. I ended up getting a DIN55 which is apparently the minimum you can have for a VR6 with 500cca. Haven't noticed anything bad about it and starts the car super quick.
    Edit: They also deliver it free of charge. They were the cheapest place I found
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
      Cheers bud, will check them out. Yeah I don't really want to crack that $200 mark unless it's really good. A friend's got some sort of tiny aviation battery in his E30, but I think they're pricey or not suitable for a daily.
        A had an Optima yellow top in my mk3. Was brilliant, could play with bags (running compressors) and crank the stereo for hours with the car off and not even come close to draining it. Expensive though, I only got it so I could relocate it to the boot as theyre safe to run inside the car
          What size compressors did you have again Ben? and two of?
          im too scared to test my new yellow tops potential
          Bora gone
          Vento VR6
          MKIV GSW TDI
          7P Touareg TDI
            Jeez that sounds the goods. Mine goes flat after about 30 seconds of the compressors on
              Re: Battery, for VR6
              I had dual viair 400cs' .
              I only ever managed to fully drain the battery once, after leaving something on for a couple days. A bitch to try and charge them by the way, normal battery charges won't work if they're really flat ae they have much lower resistance than standard batteries, so the chargers think they're shorting out and turn off
              Sent from my GT-I9305T using Tapatalk 2
                I used a Century battery in mine from battery world. I dont recall the cost (approx 150?) but never had a single problem with it. Cheap but decent indeed.
                  I was doing Alco N65 for $165, can still get if need be
                  Jmac
                  Alba European
                    Jmac
                    What's the go with those Jimmy? Just a run of the mill battery? OR are they a bit smaller?
                      They are Calcium batteries, pretty much run of the mill, but very good and reliable, haven't had any trouble with them mate sold them all the while I was in business so pretty much 5 yrs with no trouble, I run all my cars on them, rate them highly.
                      Jmac
                      Alba European
