Smoke coming from steering column
  • Smoke coming from steering column
    Hey guys, 3 posts in 2 days is a lot but this ones urgent.
    I was driving in the wet with my wipers, lights, and demister on when I noticed smoke coming from the steering column.
    I pulled over immediately after this happened, turned the car and demister off and heard a weird noise.
    Any ideas on what this is? It scared the crap out of me.
    420 dank blaze it
    short circuit somewhere in your wiring just take it to a auto electrician if your not experienced with wiring.
      Just had another look under the steering column, and there was water under there.
      Any idea how this happened and how it is affecting the car?
      420 dank blaze it
        Smoke or Steam?
        Perhaps your heater matrix has sprung a leak.
        7? MK1 Caddy
        79 B1 Passat Dasher Project
        12 Amarok
          i think its more like steam... couldnt tell the difference before.
          yeah i think it might be the heater thingy, cause my heater doesnt work!
          420 dank blaze it
            Sounds like the heater core is gone. Does it smell dodgy? Is the 'water' brown in colour?
            Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
            Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
            Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
              By pass and delete.
                Originally posted by HaydEn View Post
                By pass and delete.
                pfft weak option.
                  #because racecar option
                    yeah there is brown water in the engine bay, however I dont think the water is brown in the interior.
                    judging by the feedback, im becoming certain that its the heater matrix/core. thanks a heap
                    420 dank blaze it
                      Try turning the thermostat to heat and if mist comes out the vents you can be fairly sure its the core. Just bypass it with a corner joiner from bunnings but dont plug the tubes. And then fix it when you get the chance
                        Yes, thanks a heap! To bypass the heater core do I remove the intake and outake tubes and what an L tube there instead?
                        420 dank blaze it
                          Yep thats the way.
                            sounds like heater core....
                            There is a vent in the firewall (engine bay), centre low down, to drain it.
                            If you take your passenger side blower out you can get a mirror in there to see in
                            If not try your cabin filter under the water deflectors
                              You can use the existing pipes to bypass.
