windows down using remote
  • windows down using remote
    i was playing around with the remote trying to unlock the rear hatch when all of a sudden the windows all went down...
    dont know how i did it, they wouldnt go back up till i got in an turned ign on and used the switches to go up...
    whats that all about????
    Its a thing you can do with your OBD port. Have to ask some of the pros but apparently you can change the settings on the cars ECU to do stuff like open windows when you hold the unlock button down (my mk5 does it as well) or have all the windows go up when you lock it. My sunroof closes when you tack the keys out which is kinda annoying because its good to leave open on a hot day. Then again, safe for rain.
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
      I would assume its just from holding down the button, same as locking it with the key an holding it
        ^^^^what this man said ^^^^
        unless some idiot played with the settings on only enabled one or the other.
        in a MK4 - it has to be programmed with a BIT converter and Serial to OBD2 dongle and German DOS-Boot CD and special application.
        in a MK5 - Plug in VCDS it either enabled/disabled from CECM or from Can-Gateway from memory. It's been too long since I played with this specific changes on the MK5.
        Audi S4 (2001) - Imola Yellow
        Secret Project
