Hi all
The A/C on my wife"s Mk3 cabby has stopped working. The compressor clutch is operating as is the engine fans but the hoses/pipes remain warm.
I took it to the mechanic thinking it may need a gas. When he put the gauges on, the pressure was normal and when he started the A/C, there was no pressure change.
From what I've read here, the compressor failure seems to happen regularly but what actually occurs? Broken shaft, spline, keyway, pistons etc? It's a Sanden SD7V16.
I'm not that well informed on the VW problems but if anyone wants to throw their 2 cents worth into the ring, I'm more than willing to listen.
Any thoughts?
cheers...Andrew
Any thoughts?
cheers...Andrew
