Has anyone ever put a non VW motor in a VW? And not just the aircoolers/WRX swaps either.
just wondering
Because its heaps easier to get power out of the 1.8T than it is to get power from a VR6. $1500 will get you 147ish kw out of the 1.8T whereas the same price tag will get 135ish kw from the VR.Originally posted by ScienceVR6 View PostWhy would you replace a motor with 128kw with one that makes 110?
I've heard of Honda engine swaps, more commonly the K20A ones (S2000?). Most have been done on Mk1 and Mk2 though.
Yeah Ray I've heard of the honda swap didn't some guy put a worked Integra Type R engine into his MK1, put out around 225hp, not bad realy. I know thats a good engine, don't like the car it came from though. I've some of the toyota engines been put to good used in VW's. I've heard of some toyota motors being used like the 4AGE, and the supercharged 4AGZE I think its called. Oh and a VR6T will almost always make more power than a 1.8T.
Yeah buddy you can go for some nice agressive cams 268' or therebouts, and do some engine and CPU work i.e like a 98' octane tune, and other smaller things exhaust etc. You should be bumping a bit over 200hp with a bit of work. But these aren't big numbers, forced induction is the only alternative to drastically increasing power in smaller capacity motors.80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
just put a turbo on it, it will cost around 1500 to put a turbo on if u do all the work ur self, use 2nd hand parts, dont put high boost and u wont have any problems wit the engine and u will feel a difference in power. and if u dont want a turbo just get some stage 1 cams, hight flowed exhaust throught the whole thing from the engine,high flow air intake and if u put a pod filter make sure u do a proper cold air intake because if u dont then ull loose heaps of power. but turbo is the way to go and its not as hard to put 1 on as ppl make it to be
Got any pics and more details about your turbo set up? Also what engine have u turbo'd?Originally posted by russki View Postjust put a turbo on it, it will cost around 1500 to put a turbo on if u do all the work ur self, use 2nd hand parts, dont put high boost and u wont have any problems wit the engine and u will feel a difference in power. and if u dont want a turbo just get some stage 1 cams, hight flowed exhaust throught the whole thing from the engine,high flow air intake and if u put a pod filter make sure u do a proper cold air intake because if u dont then ull loose heaps of power. but turbo is the way to go and its not as hard to put 1 on as ppl make it to be
