Originally posted by smeghead
View Post
Basically, water is fed in under pressure in the reverse direction and then compressed air is added to this water to help dislodge any deposits. Any radiator workshop should be able to do this.
One other thing. Have you used a thermometer or proper temperature indicator to check the coolant temperature? Don't necessarily rely on what an instrument panel gauge says. Years ago, Holden simply replaced the temperature sender so that it read a lower temperature because owners were complaining because the gauge read higher than they were used to. The coolant was at exactly the same temperature, it just read lower on the gauge.
