R32 or r36 Engine Conversion idea
  • #16
    Originally posted by HaydEn View Post
    Swapped mk3 r32 with a LSD will hit 12's. If your a good driver.
    Doubt it .
    My R32 which weighs 1200kg (lighter than a mk3) , runs a best of 13.3 @ 104 mph . Has traction issues off the mark as well .
    Engine makes 297hp as well , over 50hp more than the stock one .
    Id say high 13s to be more realistic
    • #17
      Thats pretty good numbers for a 297hp r32. what tyres were you using ?
      94' Golf Mk3 Vr6
      • #18
        Paul (need_a_vr6) done 12.95 with 22" slicks and no rear seat. Furthermore; he done 13's with a basically stock 12v and stripped.
        He done 12.5 with the 3.94rp, fine tuning megasquirt and no interior basically.
        • #19
          back to the topic is it worth doing this conversion ? If i was to go Turbo with 2.8 or r32 to get 400-600hp which one would be cheaper to get that sort of power ? remember its going to be a 1/4mile and a street at the same time
          the r32 looks like it would be fun to do but pricey and plus i would have to strip and forge the internals im guessing due to it having 11.3:1 cr.
          I was also thinking of boring the 2.8 to 3.0L and forging.
          Am i making sense ?
          94' Golf Mk3 Vr6
          • #20
            It would be cheaper to do the 2.8 route. They can get to 250fwkw on stock internals. Headspacer or low comp pistons you'll make your goals easy.
            To get that much you will basically look at running at standalone. C2 can support 400~hpwith a chip but, not really certain they will be 100% here.
            Either way, 3.2 or 2.8 turbo. It'll be the same wiring just about. But much more costly to do 3.2
            • #21
              I found a 2.8 Vr6 for $350 with a knock they dont know what is wrong with it. what do you guys recon
              94' Golf Mk3 Vr6
              • #22
                If you're going to tear it down and completely rebuild it up to get it ready for a big turbo or something, id go for it If there's something seriously wrong, you could probably atleast still use some parts or maybe try and sell it again haha, worst case scenario, you could make an awesome top gear style coffee table
                • #23
                  coffee table is a good idea haha that would be so cool to keep in my garage but yeah plans are to strip it and inspect for damage and if its in good condition ill bore it out to 3.0L and forge the internals , bigger valves ,cams to hit 5-600hp street/track driven and for engine management im thinking lugtronic.
                  94' Golf Mk3 Vr6
                  • #24
                    Ive got a 2.8L 12v head thats a perfect base for a project like this, its only done 130k kms and is in good as condition if you want it ill part with it for $220 and im sure someone could take it back to melbourne from GAD next weekend if you're not coming up..
                    • #25
                      thats sounds good but i gota wait untill i ge this engine strip it apart. but ill let u know asap
                      94' Golf Mk3 Vr6
                      • #26
                        Just Pm me when you want it ill be heading melbourne way in the next couple of months so that could be another option too.
                        • #27
                          has anything been done to the head or is it bare stock ?
                          94' Golf Mk3 Vr6
                          • #28
                            Its bare stock mate, but its all there just ready for someone to start work on!
