Guys,my driver side window stopped working,I opened the door cover,the cable was off the track,looks hard to fix,still trying,the regulator is working fine,the fuse box all good,the thing is that all windows not working now!! Any ideas ?
VR6 power Windows issue
Welcome to mk3 power windows
my back right stopped working one day pulled it apart to have a look thinking I would need to fix the regulator just mucked around with the plugs and all worked fine again. So my advice is just double check all your grounds and make sure everything is plugged in properly. Weird that they all stopped though.
Iv custom mod'd all of my regulators, the problem is that theres too much plastic.
The clamp that holds that glass is held to the cable with plastic (i made a little metal plate and riveted it on. and the cable stoppers at the top and bottom are plastic. .. take the whole lot out, and spend some time at the work benchVR6 AAA
'Another Awesome Achiever'
