Vibrating at idle and a slight misfire - Vento 2.0
  • Vibrating at idle and a slight misfire - Vento 2.0
    First post after n00b intro so be patient!
    I picked up my '95 Vento on Monday knowing it had this problem but thought it would be a simple fix. It vibrates through the steering wheel at idle and I can feel a slight skip in the ignition timing, like a miss but an irregular one. I checked the sparkplugs and they seem pretty clean, number 1 and 4 were dirtier than the middle two though.
    Is there anything else I can check? Is this common?
    By the way I consider myself inexperienced when it comes to motor stuff, I've only ever done oil changes and brakes and the likes.
    '95 Golf 3dr... low. slow. loud.
