My exhaust has smelt a little rich recently. especially on startup. So today being my day off i decided to have a bit of a poke about and give the car scan with the ol vag-com.
ive thrown the below codes. Just wondering b4 i start ripping into things if anyone has experience with similar codes b4? Im thinking of swapping out the O2 sensor with a spare one i have kicking about. The codes come back within a few seconds if you clear them.
Monday,10,September,2007,12:33:09:42388
VAG-COM Version Release 704.1
Data version 20070723
Chassis Type 1H - VW G/J/V Mk3
Scan 01 02 03 08 12 15 25 41 56
Address 01: Engine Labels: 021-906-258.LBL
Part No: 021 906 258 CH
Component: MOTOR 2,8L 6-Zyl.
3 Faults Found:
00561 - Mixture Adaptation
15-10 - Adaptation Limit (Add) Not Reached - Intermittent
00537 - Lambda (Oxygen Sensor) Regulation
08-10 - Control Limit Surpassed - Intermittent
14-00 - Adaptation Limit (Add) Exceeded
Readiness: N/A
Address 03: ABS Brakes Labels: 3A0-907-379.LBL
Part No: 3A0 907 379 A
Component: ABS/EDS ITTAE 20 GI V00
Coding: 03604
Shop #: WSC 00000
No fault code found.
Address 15: Airbags Labels: 6N0-909-60x-VW2.LBL
Part No: 6N0 909 603 E
Component: AIRBAG VW2 V00
Coding: 00069
Shop #: WSC 00021
Address 25: Immobilizer Labels: 1H0-953-257.LBL
Part No: 1H0 953 257 B
Component: IMMO VWZ3Z0S0449102 V00
Coding: 09600
Shop #: WSC 00000
End --------------------------------------------------------------------------------------------------
3 Faults Found:
Readiness: N/A
Coding: 03604
Shop #: WSC 00000
Coding: 00069
Shop #: WSC 00021
Coding: 09600
Shop #: WSC 00000
