no spark & no fuel! dead ecu?
  • no spark & no fuel! dead ecu?
    gday
    I've just rebuilt the auto trans on my 2.0L 97 golf and when i went to start the car nothing happened, i checked all connections and realized the main positive wire from the battery wasn't connected to the starter and was touching the transmission case. After i rectified that mistake the car still would not start.
    Some of the problems i've identified are:
    no spark from the coil although there is a single spark when you turn the key to accessory
    no power at the injectors
    the speedo drive goes to 200kph (its not connected anyway) when cranking and the right indicator is stuck on ( although im not sure these have to do with the starting issue )
    As far as i can tell there is power to the ecu and the black wire at the coil gets switched power. All the fuses in the fuse box are intact and i can hear the fuel pump priming.
    Thanks in advance, Tom.
    1978 Golf GLS
    1997 Golf GL
    Is it in N or D??
    Auto Lockout feature?
    Try bridging from the main power terminal on the starter to the little jumper connector and see if it then kicks.
      sorry, i should have been more specific, the car does turn over it just wont start.
      it has no spark ( when holding the lead from the coil to the engine while cranking ) or fuel (i put a test lamp to the injector plug while cranking and didnt see any signs of life ) while turning over but i can hear the fuel pump priming when i turn the key to accessory so it should have fuel pressure at least.
      I'm thinking of tracking down a front wiring loom and ecu from another car in an attempt to fix the problem.
      does anyone have any ideas i could try instead of loom/ecu replacement?
      1978 Golf GLS
      1997 Golf GL
        it turns over but doesnt go to idle?
        if thats the case, could be the key barrel signal amplifier. so that the ecu says that the key belongs to the car.
        Without Your Seatbelt, You Know Your Gonna' Die!
        Project: mk1 cabriolet 20vt
          hi,
          the car was running fine ( except for the gearbox issues :S ) before, the only thing ive done is removed the gearbox, reinstalled it and without realizing shorted out the entire car ( main power wire that goes to the starter was sitting against the gearbox case )
          if i were to get a new ecu, would there be a problem regarding the immobiliser?
          1978 Golf GLS
          1997 Golf GL
            Originally posted by tommy_boy02 View Post
            hi,
            A new ECU would have to be coded to the Immobiliser but you can do that with VCDS.
