Oil everywhere!!!
  • Oil everywhere!!!
    Well sort of. There's an oil leak on my VR6. It looks like it's coming down the front of the engine block. It's a bit wierd as it leaks sometimes and then it won't leak for a while, then it will do it again. Has anyone had similar problems? Does the VR6 just leak like an eccentric european car? Is there a problem common to all VR6's? Any ideas?
    03 MkIV GTI - K04-001, APR 2.5" TBE/TIP/Software, Forge FMIC, GFB DV+, Powergasket+, Dark Tint, 17" Bora Sport, Bilstein shocks, Eibach springs, BMC CDA, Dieselgeek SS, Hella Celis, R32 Alloy Trim...
    95 MkIII VR6 (sold)
    its quite common to get a constant drip from the oil cooler seal.
    FOLLOW US ON FACEBOOK
      yeah as mentioned in the other post. have a look around the area. I had to change the seal a few years ago.
        What would happen if i unscrewed the oil cooler to replace the seal? Do i need to drain the oil first? I just changed the oil so that would be a pain. Is there anything i need to look out for? (haven't got a workshop manual yet)
        95 MkIII VR6 (sold)
          Oil pressure switch???
            it was awhile ago so don't quote me on it. but it was quite straight forward. unbolt place seal in, screw back in. I don't think you'll need to drain the oil as the oil cooler sits higher than the oil pan?
              hey tazzyvr6
              just did mine a week ago. had the same leak as u but it was constant. Its the two O rings in the oilcooler housing or something. The rings are maybe 5-7cm in diameter. Call Jacksons for em. Cheap. cost me about $15 forthe two.
              2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
              1986 SAAB 900 Turbo 16 S
                Thanks guys, i'll get the o-rings and try that then. I'll let you know how it goes...
                95 MkIII VR6 (sold)
